first layer not sticking properly on the heated bed
polo5959
(@polo5959)
Hi Everyone,
I have a Prusa mini, recently when I print something I noticed that the first layer doesn't stick corectly to the bed making the head briging plastic that should be attached to the bed. Is there a way to fix that?
Thanks,
Opublikowany : 08/07/2023 6:54 pm
Please run a first layer 'Z' calibration and show us the result *on the print sheet*
Opublikowany : 09/07/2023 1:40 pm
RE: first layer not sticking properly on the heated bed
Wash you steel sheet with hot water and dish washing liquid, dry it, then clean with 90+% isopropyl before the print. Redo the first layer calibration.
Opublikowany : 12/07/2023 12:34 am
polo5959
(@polo5959)
Thanks, yes I washed the base sheet as you said and it's much better, then re ran the Z calibration layer, all working perfectly now, Thanks!
Opublikowany : 16/07/2023 11:28 am
