Firmware 5.1.2+13478 not booting up
Commander-Ape
(@commander-ape)
Hello everyone,
i updated my Prusa MINI with the latest firmware (5.1.2+13478) but it is not booting up anymore. I tried to reflash with the same Firmware - MINI_english-german_firmware_5.1.2.bbf - but it is still not booting or showing anything.
On my display it only shows this:
Any ideas on what can cause this or how i can fix this?
Best Answer by shingdoh:
I do have the same problem. There is a github issue about it: Issue #3629 · prusa3d/Prusa-Firmware-Buddy (github.com)
For some people a hard reset worked. For me it did not, so i had to downgrade to 5.1.0 to use my printer. https://help.prusa3d.com/article/firmware-updating-mini-mini_124784
Opublikowany : 28/03/2024 5:37 pm
shingdoh
(@shingdoh)
This post was modified 2 years temu 2 times by shingdoh
Opublikowany : 29/03/2024 10:14 am
Commander-Ape
(@commander-ape)
hard reset was not possible - downgrade to 5.1.0 worked perfectly! Thank you.
This post was modified 2 years temu by Commander-Ape
Opublikowany : 29/03/2024 11:30 am
_KaszpiR_
(@_kaszpir_)
RE: Firmware 5.1.2+13478 not booting up
Try factory reset on 5.1.0, and remove all files from the pendrive and write new firmware file only
Opublikowany : 29/03/2024 10:54 pm
