File won't print on my Prusa Mini - just sits there and waits
carl67lp
(@carl67lp)
I'm having issues with a few files on my Prusa Mini. I try to print, the display just shows 0% with no obvious "stuff" going on. The temperature never changes (if I preheat, it doesn't go down; if I have it cold, it doesn't go up), and nothing moves.
This is a semi-random occurrence; it tends to be the same files, but it doesn't seem to matter what type of file (i.e. geometries, support vs. no support, etc). I even tried to do a "repair" in PrusaSlicer. Seems like many of the STLs from here are problematic, though I have been able to print a few, with PETG: https://www.thingiverse.com/thing:3901329
The Gcode for one of the files is here:  https://drive.google.com/open?id=1DxQWOcFqew0KBYITmc1CG7vzBSSazr7J
What am I missing?
Opublikowany : 03/04/2020 8:03 pm
MartinD
(@martind)
RE: File won't print on my Prusa Mini - just sits there and waits
Do you have file in 2nd folder from root? Mini does not print files from 2nd folder. Only from root and 1st folder from root.
Eg:
/file1.gcode
/Model01/version1.gcode
/Model01/Version2/version2.gcode
From these files, version2.gcode is not printable, it will be shown on menu, you can select it for print, but printer for some reason wont start print.
Opublikowany : 04/04/2020 4:57 am
carl67lp
(@carl67lp)
@martin-d17
You’re a genius! That solved the problem.
Odd thing is that I have been able to print from sub-folders before but inconsistently—so at least now I know to stop doing that.
Thanks so much!
Opublikowany : 04/04/2020 5:29 pm
