[Gelöst] Filament stuck wrapped in extruder assembly
prnthp
(@prnthp)
Hey folks. I was attempting to unload some PLA and it became stuck inside the extruder assembly. The extruder gear was not grinding or anything and seems to not catch on the filament at all. I opened all the doors and couldn't find the filament. I was able to finally pull the filament out after disassembling the extruder gear assembly. The filament was wrapped around like in the photos. I wanted to document this and see if any one has ideas of how to prevent this.
filament wrapped
Best Answer by Crawlerin:
It happens when idler tension is too high, loosening it helps prevent this.
https://help.prusa3d.com/en/article/clicking-extruder-under-extrusion-and-clogging-mini_112011 the "Extruder Idler Screw" section.
Veröffentlicht : 04/11/2020 9:17 pm
Crawlerin
(@crawlerin)
RE: Filament stuck wrapped in extruder assembly
Diese r Beitrag wurde geändert Vor 6 years von Crawlerin
Veröffentlicht : 05/11/2020 1:58 pm
prnthp
(@prnthp)
Posted by: @crawlerin
Thanks! I didn't even bother to set it when I assembled the printer. D'oh!
Veröffentlicht : 05/11/2020 9:34 pm
