Extrusion lines not connecting
Sodawasser
(@sodawasser)
Hello everyone,
I am struggling with gaps between extrusion lines . The first layers always look good, from there it gets worse.I have already contacted support about the first issue, they told me I should increase my infill which i did to 30%. It did not help unfortionately. I already changed the nozzle and the short ptfe tube, leveled the bed multiple times, tried 3 different filaments, tried adjusting the flow rate (which led to the gaps disappearing but an overextrusion) and changed the extruder gear as well as the print sheet. I also checked that the heatbreak is in the correct position/clean. Furthermore, i did lower the speeds and increased the temperature by 15 degrees. I am using the standard 0.15mm SPEED profile with Prusa rPLA, but i also tried the other profiles.
Thank you all in advance.Here are some Pictures of the Mini prints
Opublikowany : 16/01/2025 8:58 pm
carlmmii
(@carlmmii)
RE: Extrusion lines not connecting
It's not a general under extrusion problem, as evidenced by the surface quality on that stepped top.
Check/replace your bowden tube. It seems similar to the issue shown here, with the likely cause being that specific positions of the extruder rotate/compress the bowden tube enough to cause binding, leading to random sections of underextrusion.
Opublikowany : 18/01/2025 6:28 am
You are using a SPEED preset, SPEED always trades time for quality, try with one of the other settings.
Also, that is a poor orientation for that toy plane, try rotating it to about a 30° climb, change the grid supports to snug and the grid infill to cubic.
Opublikowany : 18/01/2025 12:40 pm
Sodawasser
(@sodawasser)
thanks for your reply,  I am thinking of buying a new one. I checked my old one, the excessive resistance was not prevalent in mine, it felt very smooth.
Opublikowany : 19/01/2025 10:31 pm
Sodawasser
(@sodawasser)
Yes, but as mentioned in my post, I already tried different profiles as well as speeds. Thanks for the suggestions for the plane orientation, I later tried several models, the had the same issues.
Posted by: @diem
Opublikowany : 19/01/2025 10:33 pm
