Extruder filament load speed
MB3Y
 MB3Y
(@mb3y)
I'm trying to load flex filament. I know that I shall have all gears loosely in order not to pull the filament to hard at the entry and also not to push it into a knot at the exit.
Also flex filament shall be printed slow enough to prevent the filament to get entangled. Something you can observe nicely in the printprofiles.
Unfortunately the thing that needs to be completed before one starts printing slowly is ... loading the filament...
I don't find any settings that can slow down the filament loading cycle itself. Both the MMU2S as the iMK3S extruder would benefit from bringing that speed down. (How) can I achieve this??
Thanks for sharing!
Veröffentlicht : 24/03/2021 9:07 pm
MadCyborg
(@madcyborg)
RE: Extruder filament load speed
How about loading the filament manually? The mini (you are in the Mini sub forum) can set the nozzle temp and move the extruder manually. I'm pretty sure that the other Prusas can do that as well.
Veröffentlicht : 24/03/2021 10:35 pm
MB3Y
 MB3Y
(@mb3y)
Oops, wrong forum indeed. Thanks for pointing out.
Manual load is not possible using the i3 MK3S+MMU2S...
"Load to nozzle" is a function, but there is no controlling of the speed the gears grab the filament - and I'm not sure, but I think a pre-loaded filament will be unloaded at the start of a gcode anyhow.
Reposted under https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/controlling-extruder-filament-load-speed/
Veröffentlicht : 06/04/2021 6:26 pm
