[Rozwiązany] Ethernet printing
Tim M
(@tim-m)
Ethernet printing
Hi all, thanks in advance for the assistance.
I have a Mini+ with firmware version 4.3.4.
Ethernet is plugged in and a valid IP address is assigned.
Is it possible to connect to Prusa Slicer and print via ethernet without Octoprint, etc.?
It seems like it should be, but when I try to add the physical printer in Prusa Slicer, I get the error message "Could not connect to Prusa Link: HTTP 404:"
Thanks again!
Opublikowany : 08/03/2023 12:50 pm
Tim M
(@tim-m)
RE: Ethernet printing
Solved. I thought I had the latest firmware (4.4.1) but didn't get it installed correctly. Working fine now that 4.4.1 is installed.
Opublikowany : 08/03/2023 1:20 pm
