Error 422: Unprocessable Entity -> USB Stick lost formatting
Since a few weeks, I experience every now and then a problem when uploading GCode with PrusaSlicer via PrusaLink to my MINI currently with Firmware 6.2.4.
During the upload I get this error message:
When I look at the printer, I can see that there are no more files on the USB Stick, and when I plug it into a computer the partition table is wiped (actually I'm not sure what exactly happens - remember me to dump the device next time it happens...).
When I reformat the stick and run the upload again, everything works.
Is this behaviour likely a broken USB Stick or a problem with the firmware? I noticed that 6.2.4 was supposed to fix some issues with USB - maybe a regression?
RE: Error 422: Unprocessable Entity -> USB Stick lost formatting
Sounds like a bad stick. I'll try a different one.
It's complaining about 'invalid' characters in the filename - not uncommon when switching storage between operating systems. Some exotic unicode characters mimic controls codes - stick to simple alphanumerics without spaces or punctuation and you should be OK.
More details here: https://help.prusa3d.com/article/usb-not-detected-mini-mini_230441
I'll try deep-formatting it first - but yes, that would be the cheapest thing to try. Unfortunatley, I cannot trigger this bug reliably, thus it is very hard to tell if another stick really works.
I don't think that's the case here. When this error occurs and I format the stick again, I can upload the same file from the same PrusaSlicer session without any problems. I leave the stick 100% of the time on the printer, because I always use PrusaLink. I think this error message is a symptom of the underlying problem and not the actual cause.
I dd'ed the stick and saw no issues... Formatted again as FAT32 and upload works fine so far.
If it happens again, I'll dump the stick to an image and have a look what got damaged...
I'm thinking about uploading gcode files in a loop via PrusaLink until it fails, but the printer is printing at the moment...
