Does the Mini support Firmware Retraction?
This is mainly out of curiosity, but does anyone know if the Original Prusa Mini+ supports Firmware Retraction? If yes, does it allow to modify retraction distance and Lift Z during printing?
I did a search on the forums and on google, but I found nothing (or my searching skills are getting worse with the age 🤣 )
</Zeva>
Opublikowany : 06/12/2022 7:27 pm
RE: Does the Mini support Firmware Retraction?
Hi zeva,
The retractions is nothing else than negative filament movements which can be received and executed by the printer via gcode. It is mostly a part of filament profile in prusasclicer, as different filaments need different retract. Did yo look at the prusaslicer?
Opublikowany : 11/12/2022 6:05 am
