Cracking sound with Y axis movement
Norm
 Norm
(@norm)
My Y axis about in the middle of its travel tends to crack when moving towards the back of the range of travel.
I have cleaned the printer and cannot locate anything that would cause the snapping sound.  I have checked the belts both tightness and made sure they are clean and bearings. It is perfectly reproducible when I move the bed in the Move Axis menu. It only occurs when I move the Y axis. The snaping or cracking sound is fairly loud.
The snapping sound appears to come from the underside and is not present when the printer is turned off and I manually move the Y axis. It only occurs once or twice during the travel of the Y axis in the middle of travel and only when the travel is toIMG-1300ward the back of the printer.
Napsal : 22/09/2023 9:26 pm
Larry Tener
(@larry-tener)
RE: Cracking sound with Y axis movement
Just a thought, did you check the bearing where the belt turns around at the front of the machine? I had a cracking noise and was sure it wasn’t the bed or bed bearings, found the bearing on the belt bad. Like yours, mine would make a noise about the same place every time, but that was what it was. There is a manufacturer that makes that part with two bearings in it, think it will handle the load better. Snozzle I think.
L.
Napsal : 23/09/2023 4:15 pm
Larry Tener
(@larry-tener)
SQUISHWORX Is who it was.
L.
Napsal : 23/09/2023 4:32 pm
Agreed, check the idler.
It might be a failing bearing or it may just be out of line and you are hearing it jump straight...
Napsal : 23/09/2023 5:07 pm
Norm
 Norm
(@norm)
I have ordered replacement bearing for the Y axis idler. I will install it and see if that takes care of the problem.
Napsal : 23/09/2023 7:14 pm
Norm
 Norm
(@norm)
I have replaced the idler bearing, and the cracking continues. Could it be a bearing in the stepper motor? Can those bearings be replaced or do I need to replace the stepper motor?
Napsal : 28/09/2023 4:03 pm
To check the stepper motor:  Turn OFF the printer.  Remove the belt.  Turn the motor by hand.  You should just feel the gentle bumping of the steps but it should otherwise be smooth.  A grating sensation or a noticeable variation in the force required to move it indicates a bad motor bearing.  Without specialist tools you cannot accurately replace a motor bearing, buy a new motor.
If it passes the test; when reassembling move the bed and belt to a new position.  If the noise persists is it still in the same place or have you moved it?
Napsal : 28/09/2023 4:58 pm
1 lidem se líbí
Norm
 Norm
(@norm)
I have the Y axis motor assembly and I am looking for the installation instructions. I have done some exploration and have yet to find them.  Would someone be so kind as to help me locate them?
Thank you
Napsal : 12/10/2023 12:21 am
