Copaslip or anti-seize
beeper
(@beeper)
This morning while attempting to change my nozzle for the first time on my Mini+, the nozzle sheared in half and left part in the heaterblock and part in the wrench socket (where I think it will live forever now, as it's not budging). I had the nozzle set to 280 degrees but maybe that was too much heat or not enough heat? Or maybe after a year and a half it had just firmly attached itself to the block? No idea. I know the heatbreak is also very, very firmly attached to the block and I also don't think I'm going to be able to separate those. Thankfully I had just ordered a bunch of backup parts a couple of weeks ago so I can just replace both the nozzle, break, and block. While searching for "omg wtf do I do now" info after it happened, I came across a post from 2016 where Joan says she uses Copaslip to help avoid this in the future.
I guess this is a question for her or anyone else who has used it -- has anything changed in the last 6 years where you would now not recommend it? Just checking before I replace the parts whether I should also apply some anti-seize while I'm at it. Would be lovely if future nozzle changes didn't end up requiring me to replace more than the nozzle.
Thanks!
Este debate ha sido modificado el hace 4 years por beeper
Respondido : 09/08/2022 4:45 pm
1 les gusta
I still use. Coppaslip .
And I still catch the first spurt in a tissue. To prevent coppaslip getting on the build plate
Joan
Respondido : 09/08/2022 6:50 pm
2 les gusta
beeper
(@beeper)
RE: Copaslip or anti-seize
Thank you! I have some ordered that should be delivered tomorrow so I'll wait until then to rebuild this. Thanks again!
Respondido : 09/08/2022 8:20 pm
My pleasure
Joan
Respondido : 09/08/2022 9:16 pm
