Computer wont recognise mini to upgrade
j-martin
(@j-martin)
Need to update my Mini firmware.
When I connect my Mini to either of two computers I have and open PruserSlicer>Configuration>Flash Firmware it fails.
It shows I have "USB Serial Device (COM 3)  but doesn't say anything about it being a printer or a MINI etc.
Rescan produces no change and no other options in the menu.
When I initially plugged in the Mini the computers both say they are setting up a USB device and then state it is ready to use.
No indication that it knows what the device actually is. Seems to indicate it is just a generic device.
I tried disabling my antivirus firewall. No effect.
Postato : 12/05/2020 11:27 pm
Olef
 Olef
(@olef)
RE: Computer wont recognise mini to upgrade
Firmware is updated from the USB stick. Check the manual for details.
Postato : 14/05/2020 6:35 am
j-martin
(@j-martin)
Yeah, worked that out today after hours while scouring through webpages.
Pity the main firmware, drivers and update page doesn't make that more clear.
The "How to Flash Firmware " tab at the top it takes you to a page of instructions etc that doesn't have anything separate about the mini so the user is left to assume it covers all models.
I noted that someone in the comments has also asked for Mini instructions to be added. Looks like I'm not the only one.
Postato : 14/05/2020 8:26 am
towlerg
(@towlerg)
"It shows I have "USB Serial Device (COM 3) but doesn't say anything about it being a printer or a MINI etc." Remove power from printer, if that port "goes away" it's the printer if not, it's not.
Postato : 14/05/2020 11:50 am
