Card divider is fluffy/stringy and has warts
ShadowLantern
(@shadowlantern)
I've been dealing with print issues involving extrusion clicking, hotend sagging, cleaning the nozzle, and Z adjustment. I've got my mini+ to print correctly, and I'm confident the hardware is in the right place now. However, a lot of my prints are ending up stringy and fuzzy, along with some unwanted solid noise in the fluffiest areas.  I've tinkered with retraction settings somewhat but haven't found a way to get rid of this.  Any suggestions? Could slowing the print speed help?
Napsal : 06/12/2021 3:14 am
That looks like damp filament.  Look up theads here about drying.
Napsal : 06/12/2021 1:45 pm
ShadowLantern
(@shadowlantern)
RE: Card divider is fluffy/stringy and has warts
Thanks for the suggestion, I'll see what I can do about it. In the meantime however, I'm now facing another problem I have had before, inconsistent extrusion:
I've fixed this before by cleaning the nozzle, but is there something special I have to do to prevent it from happening again?
Napsal : 07/12/2021 9:57 am
Chris Laudermilk
(@chris-laudermilk)
Do you have a better picture? I'm still fairly new to the printer myself, but that kind of looks like it's way too high.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Napsal : 07/12/2021 3:26 pm
Dry your filament.
Restore your retraction settings to defaults.
Thoroughly clean your print-sheet.
Redo your first layer Z calibration.
That should fix most of your issues, bring any that remain back here.
Napsal : 08/12/2021 6:55 am
ShadowLantern
(@shadowlantern)
Update: Tried drying the filament, cleared the nozzle, cleared dust from extruder, and tested a few prints with default settings.
Some stringiness, and one of the front corners had some first-layer issue that raised the bottom:
Final result, still pretty stringy:
I tried an additional time; the same corner issue happened, but even worse- the top level became uneven (pic taken after canceling print):
The stringiness is still there, plus this corner issue.  I could try a different filament and a different place on the bed. Any other suggestions? Is this common?
Napsal : 23/12/2021 12:20 pm
3Delight
(@3delight)
Moderátor Moderator
Have you tried lowering the filament temperature?  The one and only time I got stringing I had to lower the hot-end temperature by 5 degrees and it went away.
Napsal : 23/12/2021 2:58 pm
ShadowLantern
(@shadowlantern)
Posted by: @3delight
I will definitely try this, but I need to get the first-layer issue fixed first.
The lines on L1 are fine but each time it turns a corner, the filament comes out in beads instead of a consistent line. Likely related, the first layer sonetimes stops printing for a short time, as you can see here:
This print was canceled during L1. You can see gaps in the part that was printed. I have tested this in different areas of the print bed and that hasn't changed anything.
Napsal : 31/12/2021 8:46 pm
ShadowLantern
(@shadowlantern)
I have played with the Z adjust as well and it should be fine.
Napsal : 31/12/2021 8:47 pm
ShadowLantern
(@shadowlantern)
Update: I tried a different filament and cleared the nozzle again, and it's working better.
Lowering the temperature appears to help the stringing but not stop it entirely:
This post was modified před 4 years by ShadowLantern
Napsal : 05/01/2022 5:07 pm
