Can't flash the new firmware for the MINI+
Thomas Lynch
(@thomas-lynch)
I have a problem trying to flash the new firmware for my MINI+. I now have version 4.4.0 on it .
I have downloaded it and copied it to the USB drive several times. But when I put the USB drive into the printer nothing happens.
Did I miss something? I have done this before without any problems. The printer has been turning out excellent prints.
Tom
Opublikowany : 20/01/2023 11:05 pm
Lichtjaeger
(@lichtjaeger)
RE: Can't flash the new firmware for the MINI+
You need both files on the stick.
Maybe you deactivated the auto firmware update. Then you have to click on the boot screen.
Opublikowany : 21/01/2023 9:50 am
Thomas Lynch
(@thomas-lynch)
I checked that and it is set to "always".
Tom
Opublikowany : 21/01/2023 4:10 pm
Are both files in the root directory of the drive?
Opublikowany : 21/01/2023 4:11 pm
Thomas Lynch
(@thomas-lynch)
They're in a folder. I moved them out of the folder. But still did not work. I only have one directory on the drive.
Tom
Opublikowany : 21/01/2023 4:28 pm
Thomas Lynch
(@thomas-lynch)
I finally got it to work. I removed the folder from the USB drive. I then (in Downloads) removed the files from the folder and put them on the USB drive. Then I put the USB drive back into the printer and it flashed the new firmware. I thought I had done this before but this time it worked. Thanks for all your help.
Tom
Opublikowany : 21/01/2023 4:52 pm
Glad you're back in business. Yes, boot files have to be at the root level.
Opublikowany : 21/01/2023 4:53 pm
