Can I Remove old .BBF File After Successfully Flashing New Firmware?
AlexLandherr
(@alexlandherr)
I recently upgraded the firmware on my Mini+ to 4.3.2 as per the included manual. It worked very well. My question is whether I can remove old .BBF (version 4.3.1) file after successfully flashing new firmware? I haven’t done anything to the old file yet as I await the answer of someone more experienced.
Helpful answers are appreciated. I usually respond to Tweets directed at me.OS: Raspberry Pi OS & Windows 10. Programming Languages: Python & Java
Publié : 11/08/2021 8:30 pm
abacabie
(@abacabie)
.BBF File
If you mean .BBF file on the usb drive that you used to flash the mini with, once flashed you can delete all .BBF files from the usb drive, you don't need to leave any version on the drive.
Publié : 11/08/2021 9:09 pm
1 personnes ont aimé
You can delete the .bbf files after the upgrade.
jcjames_13009
(@jcjames_13009)
RE: Can I Remove old .BBF File After Successfully Flashing New Firmware?
Hi
No need to keep firmware version on your drive. In case you can download last or previous firmware versions from Prusa site -> https://www.prusa3d.com/drivers/
JC
Prusa MINI+ at home / Prusa MK3S+ in the Fab Lab / You can have a look at my designs here printables.com
Publié : 12/08/2021 11:49 am
