Calibration for stringing
KTH
 KTH
(@kth)
I am trying to reduce the stringing for Fillamentum PLA  Crystal Clear.
https://www.fillamentum.com/collections/pla-crystal-clear-filament
Tried a few settings and not much results except setting temp to 210C
Best result from lowering from default 215C to 210C
Fillamentum shows the min temp is 210C
Best result
How can I better calibrate to reduce stringing further?
Postato : 02/06/2021 5:55 pm
RE: Calibration for stringing
I've got notes on the process I used to eliminate fine stringing here that you might find useful.
Postato : 02/06/2021 6:06 pm
KTH
 KTH
(@kth)
Posted by: @bobstro
Thanks!
Are you able to guide me on a few things?
i dont understand most of the stuff in it.
2)
I can see my perimeter: 3
but...
where is perimeter extrusion widths ?
3)
any file for the cube?
i dont know how to create my own print
>Linear advance
Do i need to do this?
>Z-seam
my print looks good to me, so I wont change this.
Thanks!
Postato : 02/06/2021 7:17 pm
Posted by: @kth
[...] where is perimeter extrusion widths ?
Look under Print Settings->Advanced
Any 2omm cube will work. You can generate a quick one in PrusaSlicer as follows:
  1. Right-click on the print bed and select Add shape->Box.
  2. Click on the box and change the dimensions in the size settings on the right.
  3. Change Print Settings->Layers and perimeters to 2.
I've attached a simple 20mm cube STL to save you on steps 1 & 2.
  1. Change Print Settings->Infill->Fill density to 0.
>Linear advance
Not right away. It probably won't affect stringing as much as the other factors. It's not hard to do though.
>Z-seam
That's fine. Tweaking the extrusion multiplier will tend to minimize the Z seam.
Attachment removed
Postato : 02/06/2021 8:27 pm
KTH
 KTH
(@kth)
I created by own cube
20mm size.
Print settings - Layers and Perimeters - Vertical shells - Perimeters -> 2
Print settings - Infill - Infill - Fill Density - 0%
Results in picture below and next step
4) Measure the wall thickness on each wall.
I am kinda confused by this.
How do i do this?
Do i cut up the cube?
Postato : 03/06/2021 2:22 pm
You missed the bit where it says to set your top layers to zero and set infill to zero. That will give you an open topped cube with just a bottom and the walls.
Postato : 03/06/2021 3:20 pm
I'll update the notes to be a bit more clear. You don't want to get too hung up on precision, but just identify if you need to decrease or increase the extrusion multiplier a little bit.
PrusaSlicer doesn't produce walls of exactly the extrusion width once you go with more than one perimeter, so use that procedure as a rough guide.
Postato : 03/06/2021 4:25 pm
KTH
 KTH
(@kth)
Ok, I confirmed that my filament-extrusion multiplier is 1
next is the retraction, z-lift, Retraction speed, de-retract speeds calibration.
what is the min and max value for them?
Postato : 05/06/2021 12:40 pm
KTH
 KTH
(@kth)
i notice melted filament clumps or pulled together when making multiple small turns or movements in a row
e.g a small circle or zigzag
what could have caused it?
Postato : 05/06/2021 12:54 pm
Posted by: @kth
Start at 1 and adjust up or down 1-2% based on your measurements. Very slight over or under extrusion can cause problems. Think of this as a final fine-tuning step for each filament.
All of those settings are under Printer Settings->Extruder 1 in PrusaSlicer.
Postato : 05/06/2021 5:07 pm
KTH
 KTH
(@kth)
I tried to set multiple extruder but only extruder #1 is printing well.
the other extruder does not print the "outer" perimeter before zigzag inside.
My steps:
Printer Setting - General - Capabilities - Extruders - 4
Extruder 2,3,4 appear.
i went to change the setting in Extruder 2,3,4 accordingly.
Click on each model to specific Extruder #1,2,3,4
whats wrong?
Postato : 06/06/2021 6:27 am
KTH
 KTH
(@kth)
I changed a new spool of filament and i get better results.
very fine string and no blob stringing.
i think my old filament is too moist.
My question,
1) how much stringing is too much or tolerable?
2) Is drying a spool going to save it when it already "over" expose to moisture? I dried by old filament many times using a food dehydrator. And seems that it didnt help
New filament New filament
old filament old filament
Postato : 12/06/2021 4:50 pm
Posted by: @kth
Sounds like it.
Read up on drying your filament. 50-55C for 3+ hours works for me for PLA. Make sure it doesn't get too hot!
My question,
That's really up to you. I don't mind a few threads, and a quick pass with a hot air gun usually cleans those up. If you're getting enough to cause problems with the print or require extensive cleanup, definitely dry the filament.
My question,
I use 50-55C for 3+ hours for PLA. Try a bit longer. I find most filaments will recovery pretty well after drying, but it may vary by brand. If you're not having any luck getting rid of stringing with any filament, it may be time to try adjusting your slicer settings (retraction, etc.)
Postato : 12/06/2021 9:24 pm
