Blocked PTFE Fitting (hotend side)
Christian B
(@christian-b)
Utenti
While performing a cold pull, some plastic became stuck in the PTFE fitting, i.e. the double-sided nut that connects to the Bowden tube on the hotend side. Unfortunately, this is not a part that gets heated and I have a hard piece of plastic right in the middle, unreachable by pliers. Obviously removed the fitting nut but, any suggestions on clearing it out? reluctant to use brute force like hammering it with a sharp (or dull object)
Postato : 23/10/2023 7:16 pm
