[Gelöst] blank - white screen
Domnika
(@domnika)
Mitglied
Hello everyone!
My prusa mini  stopped after an hour of printing in the middle of the job.
The display is white. After restarting it is still white.
I checked all the cables...
I did not find any hints on this forum.
Please help.
Veröffentlicht : 12/01/2025 11:42 pm
_KaszpiR_
(@_kaszpir_)
RE: blank - white screen
Check if the cable between the board and the LCD display are properly seated and not ripped off.
Post pictures of the sockets and the cable.
Veröffentlicht : 20/01/2025 10:48 pm
Domnika
(@domnika)
Mitglied
Problem solved.
I read a lot of tips on the forum but none of them helped.
After a deep inspection of the buddy board, I found a tiny metal pad on it (don't ask where it came from). The pad probably made a short circuit and killed the board.
I ordered a new board and the printer is... new
Veröffentlicht : 21/01/2025 6:45 am
nolanarenado
(@nolanarenado)
Mitglied
I just create here an account to say Thank you..
Veröffentlicht : 01/03/2025 1:47 pm
qais
 qais
(@qais)
Mitglied
If your Prusa Mini’s screen is blank white, check the LCD cable it might be loose or damaged. Try updating the firmware or even reflashing it. Electrical issues can also be a culprit, so plugging into a different outlet might help. If nothing works, Prusa support is your best bet.
Veröffentlicht : 25/03/2025 8:40 am
