[Solved] blank - white screen
Domnika
(@domnika)
Hello everyone!
My prusa mini  stopped after an hour of printing in the middle of the job.
The display is white. After restarting it is still white.
I checked all the cables...
I did not find any hints on this forum.
Please help.
Napsal : 12/01/2025 11:42 pm
_KaszpiR_
(@_kaszpir_)
RE: blank - white screen
Check if the cable between the board and the LCD display are properly seated and not ripped off.
Post pictures of the sockets and the cable.
Napsal : 20/01/2025 10:48 pm
Domnika
(@domnika)
Problem solved.
I read a lot of tips on the forum but none of them helped.
After a deep inspection of the buddy board, I found a tiny metal pad on it (don't ask where it came from). The pad probably made a short circuit and killed the board.
I ordered a new board and the printer is... new
Napsal : 21/01/2025 6:45 am
nolanarenado
(@nolanarenado)
I just create here an account to say Thank you..
Napsal : 01/03/2025 1:47 pm
qais
 qais
(@qais)
If your Prusa Mini’s screen is blank white, check the LCD cable it might be loose or damaged. Try updating the firmware or even reflashing it. Electrical issues can also be a culprit, so plugging into a different outlet might help. If nothing works, Prusa support is your best bet.
Napsal : 25/03/2025 8:40 am
