Basic PrusaSlicer questions
DaveF
(@davef)
Hello, I am pretty new to 3D printing and the PrusaSlicer so sorry for the dumb questions...
I have 1 printer (Prusa MINI+) and several different types/brands of filament.  Is the best way to configure PrusaSlicer with multiple printers added, each having it's own unique set of settings (filament type, temps, speeds, nozzle size, etc.)?  Does each printer I add in the slicer contain it's own unique print settings, filament settings, and printer settings?
I added a new printer for wood PLA with a 0.6mm nozzle and ran the first layer calibration test with it.  I didn't have to adjust the Z-axis setting from the regular PLA w/ 0.4mm nozzle setting (surprisingly).  When I started my first print with the wood PLA, it doesn't do a line purge at the edge of the bed before starting the print and I noticed that the print head temp didn't kick in until just before the print instead of before the bed leveling check as usual.  I know I need to tweak it but not sure where to make these changes.
Thanks in advance for your help!
Dave Foust
Postato : 11/11/2021 6:42 pm
sylviatrilling
(@sylviatrilling)
RE: Basic PrusaSlicer questions
See https://projects.ttlexceeded.com/3dprinting_prusaslicer_profiles.html
Mk3S+,SL1S
Postato : 11/11/2021 7:09 pm
DaveF
(@davef)
Thanks, checking it out now!
Postato : 11/11/2021 7:22 pm
