Already Considering a Mod....
wyldbill
(@wyldbill)
Anyone else thinking that this is a marriage made in heaven?
If I just knew the length of the bowden, I could place a pre-order.....
Opublikowany : 25/10/2019 7:31 pm
RE: Already Considering a Mod....
Posted by: @wildbill_220
That battery confused the hell out of me! I'd be more curious to see how that performs on a Creality-class printer.
Opublikowany : 25/10/2019 9:45 pm
wyldbill
(@wyldbill)
Given the majority of the concerns I’ve “heard” with the Mini so far have to do with the bowden aspect, having the option of a vey lightweight, direct drive extruder could be very interesting for some folks. Especially for those printing flex; there seems to be quite a bit of doubt that it’ll go well given the bowden.
time will tell.
Opublikowany : 26/10/2019 4:39 pm
The mmu1 was bowden
 Every delta printer i know of is bowden as are all ender3,s
If tpu was a big problem they would be unpopular
Regards Joan
Opublikowany : 26/10/2019 4:53 pm
Saij
 Saij
(@saij-2)
I doubt that the Nimble would be better than the bowden.
You might have the filament drive as direct drive but the connection between motor and drive gears I think will have some play where you can't get a good drive of the filament.
Maybe for longer bowden it is an option but for the short bowden path on the MINI I don't think it might improve much.
Opublikowany : 26/10/2019 5:26 pm
featherz
(@featherz)
I print TPU all the time on my creality (bowden), no problems at all..
Opublikowany : 26/10/2019 5:53 pm
I'm not sure it will help the Mini, but a lot of the inexpensive bowden-style printers are saddled with heavy hotends, negating one big plus of the bowden approach. Would be curious to see if a cheap printer might see some performance benefits with a "proper" light hotend. The Prusa Mini design already looks pretty lightweight.
Opublikowany : 26/10/2019 8:47 pm
