About beep
James
(@james-13)
About beep
how can let mini beep when done?
thanks
Postato : 09/03/2022 12:06 pm
RE: About beep
At the moment you cant with a standard mini.  The mini firmware does not support the M300 gcode to play sounds.  Normally you would add some M300 codes to the end gcode section in your slicer and it would do the sounds at the end.
The other normal method is built into firmware and the printer plays the end sound without it being in the gcode.  Unfortunately the mini firmware doesnt do that either.
There are a couple of related github requests https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/334 and https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/1075 at least (there may be others).
Postato : 09/03/2022 12:17 pm
James
(@james-13)
RE: About beep
I see  , thanks
Postato : 09/03/2022 12:37 pm
