Abnormal wall surface quality when printing simple enclosure
Jacksee
(@jacksee)
it's the first time it has happened to me. I've been using my Prusa Mini (self-assembly kit) for over a year and I have just encountered this wierd line and uneven surface on one side of my print. What could be the cause? Could it be the nozzle wear (I wouldn't be surprised since my printer has seen heavy use many times) or it's just a one time bug? My belt tension might be on the low side, could it impact the quality that much?
I'm using the latest firmware. I used good quality PLA spool (with which I've never had any problems before) in this print. All of my printer's parts are originals from the official kit.
Publié : 23/08/2023 8:30 pm
_KaszpiR_
(@_kaszpir_)
RE: Abnormal wall surface quality when printing simple enclosure
Did you use Prusa Slicer, if yes then what version?
Do you have previously saved gcode files od the same model, and if yes does it print differently?
Publié : 24/08/2023 8:14 am
Jacksee
(@jacksee)
I used the latest version of Prusa Slicer. It was my first time printing this model. I uploaded it via Prusa Connect.
Publié : 24/08/2023 6:58 pm
