3 thermistors on mini+?
Jonathan
(@jonathan-5)
The homepage says the following:
Safety Features
Every part we use is thoroughly tested in-house. This is why our 3D printers are highly reliable and safe to use. The MINI+ is equipped with three thermistors and comes with a high-quality power supply (Delta or Mean Well - depending on region) for safe and reliable information.
I checked the manuals and the thermistors replacement guides, I can only find two: heatbed + hotend. Where is the third located?
Thanks
Jonathan
Respondido : 05/02/2023 9:53 pm
SkermiebroTechTips
(@skermiebrotechtips)
RE: 3 thermistors on mini+?
I dont own one myself but I would say there may be one on the control board
Respondido : 05/02/2023 10:28 pm
Jonathan
(@jonathan-5)
that would at least make sense. Thanks
Currently, I'm assembling one. If I only new what part to look for. Once done, maybe I go hunting specs of the board.
Respondido : 15/02/2023 6:56 pm
René
(@rene-3)
That is an smd version NTCG104LH104JTDS,
which you can find at position TH1.
This is probably used to check whether the head bed connector does not get too hot.
Respondido : 16/02/2023 7:54 am
