2 month old Mini+ losing precision on the x axis
cwjohn67
(@cwjohn67)
I've printed several models over the last two months and been very impressed with the output. In the last week I've had one model start showing imprecise x axis layers.  I do not see problems with the belt teeth or tension of the belt.  is there anything else I should be looking at?  Layers in the Y and Z axis' still look good.  I have not re-sliced the mode or changed the gcode since my first print of it.
This is the model that is starting to show x axis problems - https://media.printables.com/media/prints/57885/stls/635616_81ca8f3d-b82e-47db-9e0a-395e94616bf4/outside_shell_square.stl#_ga=2.177002469.1112705216.1657907475-1841166403.1657907475
sliced in Prusa slicer, prusament pla, configured for the Mini+.
I have two copies that are perfect and now two that have the x axis layer offset (left and right, not just to one side) about .25" up from the start of the print and then the rest of the models is perfect.
Este debate ha sido modificado el hace 4 years por cwjohn67
Respondido : 15/07/2022 6:08 pm
