[Risolto] Klipper back to Prusa
Justin
(@justin)
Looking to change my firmware back, just didn't enjoy the massive configuration Kilpper and mainsail needed. When I try and go back i get error #2 cant mount USB drive. Both that I've used are formatted for FAT32 so there should be no issue. Since it can not mount them it goes to the screen showing Developer Firmware.
Postato : 27/05/2022 2:14 am
Utenti
RE: Klipper back to Prusa
You might want to ask in Chat.  I doubt that they will be able to help since you moded your control board, but it is worth and ask.
Postato : 27/05/2022 10:42 am
DaTePrusa
(@dateprusa)
Hi Justin, I'm quite curious about klipper but want to know I can revert back, have you managed to restore stock firmware? Cheers
Postato : 21/06/2022 10:08 am
Utenti
That is a huge concern and I suspect the answer is No on the mini.
Posted by: @r3gistrar
Postato : 21/06/2022 11:17 am
DaTePrusa
(@dateprusa)
Hi again, not sure if you're still looking for a solution and I haven't tested the flashing myself (not running klipper yet) but I've been following the instructions on keenzkustoms : https://github.com/keenzkustoms/klippermini
I've managed to successfully compile the firmware in DFU format with bootloader, said bootloader which to my (little) understanding you might have overwritten when installing klipper.
You can either compile it yourself or let me know if you need the file,
Cheers
Postato : 23/06/2022 10:26 am
Zoltan
(@zoltan)
Utenti Moderator
Using the on the github provided build via python you can define the output format .dfu, then loading the fw via stm dfu loader. The build contains also the bootloader as dateprusa mentioned. For dfu load you have to break the appendix taking in account all warranty consquences. But loading the clipper you had to break the appendix anyway.
Postato : 11/12/2022 9:14 am
Fzank
(@fzank)
Could you give me more help to get back prusa slicer?
I'm running klipper but want to sale printer for bigger size and buyer wants prusa firmware.
Thanks you very much
Postato : 09/05/2023 4:35 pm
Zoltan
(@zoltan)
Utenti Moderator
Hi without flashing back the bootloader  you will not succeed. But this requires some programming knowledge and braking the appendix, which is cancelling he warranty.
Postato : 16/05/2023 7:10 am
Fzank
(@fzank)
Appendix is already broken
Postato : 16/05/2023 7:23 am
Zoltan
(@zoltan)
Utenti Moderator
Whoops
I missed your answer, did you mange in the mean time?
Postato : 01/02/2024 12:04 pm
