Why is Retraction not in Filament Settings
Gary B
(@gary-b-2)
Mitglied
Why is the Retraction Settings in Printer Settings? Would it not be better if it were in Filament Settings so it would travel with that particular filament?
Veröffentlicht : 18/10/2023 6:27 pm
RE: Why is Retraction not in Filament Settings
You can override the defaults set under Printer Settings in Filament Settings→Filament Overrides.
Veröffentlicht : 20/10/2023 12:40 pm
Use the same filament in a MK3 and the direct drive extruder retraction value is around 0.8mm, load it into a printer with a bowden tube extruder like an ender 3 and its around 5mm, so why shouldn't it be in the Printer settings ?  Its mainly a function of your physical extruder design.
As Fuchsr points out you can set up an override in the filament profile.  Although they are usually used to override where a particular filament needs more than the extruder.
Veröffentlicht : 20/10/2023 12:48 pm
