Prusa Printer Bed Leveling Reader (no Octoprint needed)
Pedja
(@pedja)
I've created simple tool to read and visualize bed leveling data from Prusa printer attached directly to USB port on Windows. It is meant to help those that do not have Octoprint but want to fiddle with bed leveling.
https://pedja.supurovic.net/projekti/prusa-printer-bed-leveling-reader/?lang=lat
It is an early version so feedback is welcome.
Program is freeware.
Opublikowany : 01/01/2022 11:10 am
2 ludzie polubili
Damiano_PL
(@damiano_pl)
RE: Prusa Printer Bed Leveling Reader (no Octoprint needed)
@pedja
It will work on Mk3S and Mini ?? Prusa Mini have 5 point of probing default. Working table dimensions are'nt important ??
Opublikowany : 03/01/2022 11:00 am
tkdchris
(@tkdchris)
Great little program, I do find that it doesn't always produce the colour plot at the end of the run though...
Opublikowany : 17/01/2022 11:47 am
Pedja
(@pedja)
Posted by: @damiano
@pedja
I expect it should work on both. I use it on MK3S ant that is only one I tested.
MK3S always returns full result point matrix regardless how points are actually probed. If mini does the same then it should work fine. Ifnot then I will have to see what is response from the printer to add support for it.
Opublikowany : 17/01/2022 5:00 pm
