pronterface doesn't work on ubuntu? (Command not found)
Pronterface used to come pundled with prusa-slicer, but no longer does. I need it to send commands and receive results to calibrate my extruder. If I install ponterface and connect to my MK3S, it connects fine. However, when I try to type in a command it sits there for a while and then says "Command not found". I suspect this has something to do with the python connection, but don't have a clue how to diagnose/fix it. ponterface itself is invoked via python3; I thought it might be trying to use "python" instead of "python3" as a command, so added a symlink for python->python3 but that didn't affect anything. What's the necessary magic?
Postato : 25/04/2024 11:16 pm
