Problem with hollow mesh
Dr_Froggy_rD
(@dr_froggy_rd)
Dear all
 I got a strange sliced result last day,  where prusaslicer  did add a support layer below an empty location
As the st below
This topic was modified 4 years temu by Dr_Froggy_rD
Opublikowany : 02/12/2021 11:45 am
Dr_Froggy_rD
(@dr_froggy_rd)
RE: Problem with hollow mesh
Here a picture of the player once sliced
Opublikowany : 02/12/2021 11:46 am
Probably an incorrect model.  Rather common.  If you want that confirmed you will have to supply either the model in question or (better option) a saved Prusa Slicer project file that is showing the issue.  The project file (file>Save project as) will be a *.3mf file and is better as it also contains all the settings you are slicing with so its better for debugging issues.
Whichever method you would need to zip up into an archive for the forum to allow you to attach them.
Opublikowany : 02/12/2021 12:14 pm
