Problem to reconnect with OctoPrint after disconnect via knob
HermannSW
(@hermannsw)
Lately I did a lot of PETG prints with my MINI+:
https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/my-longest-mini-3dprint-525x8-cm/#post-611832
When heatbed was already cooled down, I had big problems to get the 0.5mm high parts off, even with scraper.
I found solution, used knob to disconnect and then preheated with knob for PETG (heatbed 85°C).
When 85°C was reached, removing parts from heatbed with scraper was easy.
Now to my problem, I tried "Connect" in OctoPrint, but that did never work.
I found a workaround, used "Restart OctoPrint" option of OctoPrint, and then I could continue printing.
Question:
Since restarting OctoPrint takes more than 2 minutes, is there a shorter procedure to reconnect OctoPrint after disconnect with knob?
Posted : 29/06/2022 12:02 pm
mark Cora
(@mark-cora)
RE: Problem to reconnect with OctoPrint after disconnect via knob
nice post
Posted : 30/08/2022 5:45 am
bmorgenthaler
(@bmorgenthaler)
@hermannsw
Did you ever figure out a better way for the reconnect? If I ever disconnect from the knob I have to restart Octoprint and sometimes the printer itself to get Octoprint to reconnect successfully.
Posted by: @hermannsw
Question:
MINI+ with FW:4.3.3, Bondtech IFS Extruder, drilled out PC4-M8 couplers, 1 piece Capricorn bowden.
Posted : 05/09/2022 11:24 pm
HermannSW
(@hermannsw)
Posted by: @bmorgenthaler
@hermannsw
No.
Posted : 07/09/2022 9:46 am
