CLI: Add SVG as negative volume / Support for elements in SVGs
Is there any way to add an SVG file as negative volume to an existing SVG already added to the slicer using the command line interface only? I know it's possible with the GUI but I simply couldn't figure out how (if possible) to do it with the cli.
I already tried to merge the SVGs before adding them to the slicer by using a mask ( https://developer.mozilla.org/en-US/docs/Web/SVG/Element/mask ) but the slicer does not recognize the syntax correctly.
Opublikowany : 22/07/2024 3:35 pm
