CLI: Add SVG as negative volume / Support for elements in SVGs
RevoAlex
(@revoalex)
Membre
Is there any way to add an SVG file as negative volume to an existing SVG already added to the slicer using the command line interface only? I know it's possible with the GUI but I simply couldn't figure out how (if possible) to do it with the cli.
I already tried to merge the SVGs before adding them to the slicer by using a mask ( https://developer.mozilla.org/en-US/docs/Web/SVG/Element/mask ) but the slicer does not recognize the syntax correctly.
Publié : 22/07/2024 3:35 pm
