SUGGESTION: Prusa Connect File Management Features Needed
Jeff Hawkins
(@jeff-hawkins)
I just ran into the "Forbidden Storage capacity exceeded" issue... Tried to debug, then Googled it. Understood that the storage was full. Deleted dozens of large files from the printer. Still not fixed. Googled some more... Understood that the storage on Prusa Connect was full. Went to Prusa Connect and deleted several large files from there. Still not fixed... Poked around and discovered that deleting from the normal UI in Prusa Connect does not remove them from Prusa Connect. Found the file list... Looked for a way to delete all... Can select all, but not then delete them. So, spent 20+ minutes deleting all the files one by one.
If you had trouble reading that, imagine how much it sucked for me to do it. This was a terrible used experience for an "everybody" issue. Literally every person who uses Prusa Connect will run into this at some time if they use their printers much.
SUGGESTIONS:
  1. Need a better, more helpful error message. (Hopefully only temporarily, as users should not run into this with other improvements.)
  2. Need a preference that is obvious to new users, and easily switched on a per-print basis, for whether or not to retain the file on Prusa Connect after transfer to the printer.
  3. Need a delete operation that works on all selected (checked) files.
  4. Need (possibly as an option) to delete from Prusa Connect when using "Delete from Printer" from Prusa connect. Meaning, if it auto-stores the file on transfer to the printer, it should at least have the option to auto-delete on delete from the printer.
  1.
Napsal : 19/03/2024 8:43 pm
2 lidem se líbí
RE: SUGGESTION: Prusa Connect File Management Features Needed
This would be better raised on the Prusa Connect Git Hub Page
Napsal : 19/03/2024 11:54 pm
1 lidem se líbí
Tojik
(@tojik)
Member Moderator
Hey, appreciate you watching over the forum. Unfortunately as Connect is not opensource it does not have a github page. I monitor these three sections of the forum, however the official feedback is the orange tab in the bottom right corner of Connect.
That said, it should be possible to delete all files from Connect storage - in the bottom left of the screenshot below
The error probably should say something like "Connect storage quota exceeded" instead
Napsal : 20/03/2024 9:54 am
2 lidem se líbí
As much as I enjoy using PrusaConnect, file management is one of the weakest aspects of it. Specifically, the inconsistencies between file management features for PrusaConnect and on the printer. Ideally, I'd like to be able to create directories, drag files around, and delete one or several files at a time. Some of this works in one part of the PrusaLink/Connect ecosystem but not the other.  I do appreciate that the fact it relies on USB storage on local printers creates its own set of (admittedly homemade because using USB storage was a choice) issues, others—like no folders or at least tags on PrusaConnect—are a bit harder to understand. Having folders or tags to organize models by project, customer, etc. would be super useful. Right now my PrusaConnect storage is a hot mess of unorganized files.
Napsal : 20/03/2024 12:43 pm
langjai
(@langjai)
Can we have file retention policies? Examples:
  1. delete everything older than a certain time period
  2. delete all files larger than X MB
  3. delete all files of a certain filament type or nozzle size
  4. delete all files successfully transmitted to printer
Personally, I'd implement #4. I like Prusa Connect (cloud) since it's more fully featured than PrusaLink (local). However, I have no need for PrusaConnect to hold my files since they're already being transmitted to local flash drive before printing.
Napsal : 04/11/2025 12:50 am
1 lidem se líbí
ronguest
(@ronguest)
Another approach that would cover several of these needs: delete all files that match a filter (any of the existing filters). Currently applying a filter only shows a subset of the matches so clicking the box to select all only selects the ones that are visible.
I have to admit I don't know why someone would want to keep files on Connect long term (that's a rhetorical).
Napsal : 09/11/2025 3:42 pm
langjai
(@langjai)
I see benefits if you're a print farm owner exclusively using Prusa Connect. However, even for a print farm owner, the file management features of PC are lacking. It's missing stuff like folders, tags, print groups, etc. just to name a few. For normal hobbiests or home users, storing files in PC isn't necessary and there should be an option to turn it off.
Napsal : 09/11/2025 3:51 pm
1 lidem se líbí
