PrusaLink on Raspberry Pi 3B and 4
SaguaroMaster
(@saguaromaster)
I have just set up my MK3S with PrusaLink using a Raspberry Pi 3B, it totally works. So if you want to try it but dont have a Zero W/W2 because practically it is never in stock, you totally can. Just use a separate power source, in my case a buck converter from the 24V PSU and connect the required pins with jumper wires. Pins are the same.
I just wanted to share this, as I have not found any information about it anywhere.
Napsal : 19/05/2022 8:27 pm
Tojik
(@tojik)
Member Moderator
RE: PrusaLink on Raspberry Pi 3B and 4
Yup, It will be in the new readme file. But it's probably not gonna make the official guide. If you do a little bit more configuration, you can use the USB and I think that is probably the more user friendly way to go about it, but this is totally fine as far as I know.
Napsal : 19/05/2022 8:59 pm
2 lidem se líbí
BENKO
(@benko)
Posted by: @tojik
Hey Tojik,
I only have the Pi4 (Raspberry Pi Zero W is no where to be found), could you please write down the configuration for it?
Thanks.
Napsal : 18/07/2022 6:07 am
1 lidem se líbí
Comp
 Comp
(@comp)
Would also like to know how to connect via a USB PI 4 and PrusaLink
Cheers.
Napsal : 23/07/2022 8:49 am
Eric E
(@eric-e)
https://forum.prusa3d.com/forum/bugs-errors/0-5-2-documentation-missing-for-usb-and-non-zero-pi/
It works just fine.
Don’t trust forum advice.
Napsal : 23/07/2022 4:41 pm
2 lidem se líbí
Ed
 Ed
(@ed-5)
I use a pi4 over USB, works great.
Napsal : 31/07/2022 6:18 pm
2 lidem se líbí
