PrusaLink + MMU3
Lobbelt
(@lobbelt)
PrusaLink + MMU3
Is there support for the MMU3 in PrusaLink? This week I assembled and got my MMU3 working (did a couple of prints with it as well) and today installed the RPI Zero 2 W with PrusaLink on it. However, upon my first test, I still had to manually select the filament on the printer as PrusaLink did not "detect" the MMU3 or at least did not present any options relating to it.
Is there anything I am missing here? Thanks!
Opublikowany : 25/10/2023 10:23 pm
Lobbelt
(@lobbelt)
RE: PrusaLink + MMU3
I probably should mention that the gcode I sent for printing was not sliced for MK3S+MMU3, which is probably the reason why I had to manually select the filament.
Sorry for not thinking about this sooner.
Opublikowany : 25/10/2023 10:46 pm
Ooops!
thanks for letting us know what you missed...
I sometimes do the same thing, as I Work with a number  of different printer formats, including MMU1 and MMU3.
Opublikowany : 25/10/2023 10:59 pm
Tojik
(@tojik)
Member Moderator
Hi, it won't be possible to select the filament in PrusaLink, the MMU support will mostly consist of mmu information being relayed to Connect
Opublikowany : 26/10/2023 8:24 am
