Prusa Teams and Prusa Connect Files Issues
c60nils
(@c60nils)
I've setup teams for my personal printer but uploading of files to prusa connect does not show the files under the teams printer for prusa connect files but on my original prusa account.  I'm seeing a similar behaviour on our teams account for the makerspace.
Should I report this as a bug?
Some more documentation on using teams and how it interacts with prusa connect and the cloud file repository in usage at a shared space would be greatly appreciated.
Napsal : 03/04/2024 4:05 am
c60nils
(@c60nils)
RE: Prusa Teams and Prusa Connect Files Issues
Just to clarify when I talk about uploading I'm talking about through prusa slicer,  not by dragging it onto the webpage.
Napsal : 03/04/2024 4:38 pm
Tojik
(@tojik)
Member Moderator
Hi, so you moved your printer into your newly created team but files upload to your personal one, is that correct? Thanks
Napsal : 04/04/2024 1:23 pm
c60nils
(@c60nils)
Yes, I added a new team.
Added the printer to that team.
Then I use the API token for the Printer in Prusaslicer.  As there is no API token for the team only the printer.
When uploading from Prusaslicer it is in my original account's connect files not the teams.
Do I need to download the prusa_printer_settings.ini configuration file for the teams account and re-add the printer that way?
Napsal : 04/04/2024 7:48 pm
Tojik
(@tojik)
Member Moderator
I don't thhink that would do anything. From what you described it really seems like we upload to the user's default team and not the printer one
Napsal : 08/04/2024 2:49 pm
c60nils
(@c60nils)
I tried adding the printer via the setting menu on prusa teams using the prusa_printer_settings.ini file it supplied in the team.   The printer shows up as part of that team in prusa connect but the files are still not being stored in the teams connectfiles.  This is not the desired behaviour.  It seems the api key for the printer is the same and I can't see anywhere within the teams interface there is another api key.
Is there another way that one is supposed to add the printer to teams or for prusaslicer to connect to the team so the connectfiles are in the right place?  This is starting to be an issue at the makerspace I'm at with so many users.
Thanks
Napsal : 25/05/2024 10:58 pm
Miroslav
(@miroslav)
@tojik any progress with this topic?
We are facing same API key issue when using teams and PrusaSlicer..
Thank you
Napsal : 13/02/2025 5:54 am
Tojik
(@tojik)
Member Moderator
Hi, unfortunately that is how uploading works now. We are aware that it is not ideal, but we have other priorities. Sorry
Napsal : 13/02/2025 1:23 pm
