Prusa Mini still not on here 😢
Richard Burke
(@richard-burke)
When is the mini likely to be added to Prusa Connect?  You have a new board for the MK4, 32bit and it goes straight in, surely this is something that should have been solved by now
Opublikowany : 31/03/2023 5:27 pm
Tojik
(@tojik)
Member Moderator
RE: Prusa Mini still not on here 😢
We are trying to make sure we can take all the minis connecting after the update. It should come in the next version as far as I know. I suspect everybody has their hands full with the MK4 and XL release tho.
Opublikowany : 31/03/2023 5:33 pm
Richard Burke
(@richard-burke)
Yes it’s certainly a big launch, but like I said you have the Mk4 already on there with a new board.  I just hope that as you say it will be in the next version and Mini users don’t get forgotten about as they get used for farms aswell as the other machines 👍
Opublikowany : 31/03/2023 5:39 pm
Tojik
(@tojik)
Member Moderator
Mini runs on the same codebase as the xl or mk4, it just has less flash to work with. Don't worry. Connect support is coming
Opublikowany : 31/03/2023 5:41 pm
Richard Burke polubić
printing overnight
(@printing-overnight)
The Mini has had PrusaLink working since 4.4.0 (Nov 2022), so PrusaConnect shouldn't be too far away.
Did you add an ESP-01 to your Mini+?
Opublikowany : 31/03/2023 7:10 pm
Richard Burke
(@richard-burke)
Yes it’s all installed 😊
Opublikowany : 31/03/2023 7:12 pm
Tysonsw
(@tysonsw)
What will the capabilities be for the Mini with Prusa Connect? Will we be able to use for example USB-webcam that are connected to the usb-A connection? Or will they have to have some kind of raspberry pi as a mediator?
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Opublikowany : 23/05/2023 2:15 pm
Tojik
(@tojik)
Member Moderator
The buddy platform can not send images. The only way to connect a camera is externally. For now, camera support through a browser app is the only way to do that. We should add more. There is an experimental community project to add esp cam support and it seemed functional
Opublikowany : 23/05/2023 3:21 pm
Tysonsw polubić
Tysonsw
(@tysonsw)
Thank you for the quick answer. Is there update on the ETA for Prusa Connect on the Mini? Q2, Q3, Q4 or 2024?
Printables: Tysonsw
Opublikowany : 23/05/2023 3:24 pm
Tojik
(@tojik)
Member Moderator
As far as I know it was the end of the last year. No, no ETAs, never. You do not ask devs for ETAs. We work in a different space time. We cannot predict in human timeframes 😅
Opublikowany : 23/05/2023 4:38 pm
Tysonsw polubić
Tysonsw
(@tysonsw)
Posted by: @tojik
"An update is never late, nor is it early. It arrives precisely when it means to. "
- Wizard Developer
Printables: Tysonsw
Opublikowany : 24/05/2023 8:18 am
Tojik polubić
johnyHV
(@johnyhv)
Hi. I have simple project on the github with ESP32-CAM board. Where ESP32-CAM board sending photos to Prusa connect backend, and then is possible see photos from ESP32-cam board in the Prusa Connect WEB page. Project is stored here.
https://github.com/johnyHV/PrusaConnect_ESP32-CAM
In the project I use same interface for sending photo from smartphone to Prusa Connect WEB page (what is official option how to sending photo from external browser to Prusa Connect WEB page).
Opublikowany : 25/05/2023 12:26 pm
Rainer i Tysonsw polubić
Tojik
(@tojik)
Member Moderator
Posted by: @tojik
Okay, I've been corrected. Connect stability is not the main sticking point. The MINI FW itself needs more work to function with connect properly. Sorry about the incorrect info.
Opublikowany : 30/05/2023 7:58 pm
Tysonsw polubić
11seashell11
(@11seashell11)
Any chance we can build support into the raspberry pi version to support the mini? I already have raspberry pi's connected with cameras and I'm guessing the extra compute power wouldn't hurt....
Opublikowany : 05/06/2023 1:27 am
Tojik
(@tojik)
Member Moderator
That has not been greenlit, so as far as I know, no. The RPi version of prusalink won't get MINI support. Sorry
Opublikowany : 05/06/2023 9:53 am
printing overnight
BREAKING NEWS:
New firmware 5.1.0-alpha1 will get you covered.
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v5.1.0-alpha1
Opublikowany : 19/09/2023 2:59 pm
Richard Burke
(@richard-burke)
Yes I’ve installed it today, works really well
Opublikowany : 19/09/2023 3:00 pm
