Prusa Connect Notifications - Customizations
Bytor
(@bytor)
I looked around and I couldn't find anything on this topic so I figured I'd ask. Is anyone aware of a way to customize the notifications from Prusa Connect?
For instance I have Notifications set up to send to my Discord server which works great. What I have an issue with is the messages that are sent. For instance when I start a print job the notification that I receive is:
                 "Printer Name: Printer requires your attention. Check it personally to make sure everything is in order."
When the print job finishes the notificaiton that I receive is:
                  "Printer Name: Print Job "file" was finished. Remove the printout from the printer and prepare the printer for the next print job."
If I stop the printer the notification that I receive is:
                    "Printer Name: Print Job "file" was stopped. Remove the printout from the printer and prepare the printer for the next print job."
What would be nice is if the notification when I started a print would say that the Print Job "file" was started instead of what it currently says. Also, maybe color code Started, Stopped, & Finished. Shouldn't be too hard to allow this... afterall some of the information is color coded such as "Printer Name" and "File name".
Maybe have a configuration file for Notifications that has the phrase you want sent and any specific formatting (bold, italic, etc, color, variables added in.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Opublikowany : 30/03/2026 8:13 pm
jan.d.slay
(@jan-d-slay)
RE: Prusa Connect Notifications - Customizations
This is a question many users are asking—when will this change be implemented?
I was told that it will be implemented in 2026.W
e'll have to wait and see.
Opublikowany : 31/03/2026 7:00 am
