Deletion of folders in the Storage location
Just1Ivan
(@just1ivan)
I looked around other topics and didn't locate this question, so I'm posting.  Is there a way (outside of SSH/RMDIR) that we can delete folders in PrusaLink from the GUI?
Respondido : 26/03/2023 3:05 pm
Tojik
(@tojik)
Miembro Moderator
RE: Deletion of folders in the Storage location
Yep, you're right, there's no way to remove folders. There also seems to be no way to create one. Also we know selecting multiple folders or files for deletion would be appreciated. I think the delete will be easy enoug, so it'll probably make its way to the next release.
Respondido : 27/03/2023 9:30 am
Just1Ivan
(@just1ivan)
The only way to create is through the SSH.  Either way, when you open Pandora's box of delete, and create, you will inevitably get the request to change names, etc.  Thank you for all you do for this community and the product.
Respondido : 27/03/2023 11:31 am
Zbigniew Trzepizur
(@zbigniew-trzepizur)
Posted by: @just1ivan
The only way to create is through the SSH. [..]
When you send a gcode from PrusaSlicer to PrusaLink (using API key) and enter a path with subdirectories in the file name dialog, all the directories will get created as needed.
Respondido : 28/03/2023 10:48 am
Tojik
(@tojik)
Miembro Moderator
Well, there's an API way to delete them but no gui yet, so if you edit a request creating the folder, you could edit the one for deletion too 😅
Respondido : 28/03/2023 11:49 am
