Confused by the connect files process.
So I have a Print called for example:
benchy.gcode.
1. I up load that to connect.
2. I print via connect Files to printer 1
3. I go to print again on printer 1 via connect files... it errors and says "File is already on printer. "
I would expect it to check the file is not a new one and then just print the local file? Is that not what happens?
Follow up?
If I upload a new gcode file to connect file with the same name does it overwrite the old one? And then when I print it overwrites the old one on the printer?
Opublikowany : 13/05/2024 6:22 pm
