Z Y axis selftest failure
DBuhr
(@dbuhr)
Recently updated the firmware to 6.2.2, and the selftest won't go through.I did a bit of online research, and found that others where experiencing the measurement of the axis being off. Same in the case of my machine.Some have had success adding small spacers to hit within the expected range, but I was wondering if there is some way to enter a "secret" menu and adjust the values?
Here is the output from the log file:
52.734s
[INFO - FileSystem:7] Started logging to file: /usb/log.txt77.134s
[INFO - Selftest:10] Fan test 0 started88.234s
[INFO - Selftest:10] Print fan 0 4755 RPM in range (10 - 10000)88.234s
[INFO - Selftest:10] Heatbreak fan 0 8090 RPM in range (10 - 10000)106.434s
[INFO - Selftest:10] Print fan 0 2370 RPM in range (10 - 10000)106.434s
[INFO - Selftest:10] Heatbreak fan 0 5229 RPM in range (10 - 10000)110.876s
[INFO - Selftest:10] X-Axis Started110.979s
[INFO - Selftest:10] X-Axis home single axis110.979s
[INFO - Marlin:10] enqueueing "G28 X"112.979s
[INFO - Marlin:10] busy: processing114.979s
[INFO - Marlin:10] busy: processing115.816s
[INFO - Marlin:10] endstops hit: X:182.73115.827s
[INFO - Marlin:10] X:180.40 Y:-3.00 Z:4.00 E:0.00 Count X:18040 Y:-300 Z:1600116.038s
[INFO - Selftest:10] fwd X-Axis @50 mm/s116.038s
[INFO - Marlin:10] X:180.40 Y:-3.00 Z:4.00 E:0.00 Count X:18040 Y:-300 Z:1600119.804s
[INFO - Marlin:10] endstops hit: X:-0.57119.854s [INFO - Marlin:10] X:-0.57 Y:-3.00 Z:4.00 E:0.00 Count X:-57 Y:-300 Z:1600119.854s
[ERROR - Selftest:10] X-Axis measured length = 181.369995mm out of range <182.000000,192.000000>122.034s
[INFO - Selftest:10] Y-Axis Started122.137s
[INFO - Selftest:10] Y-Axis home single axis122.137s
[INFO - Marlin:10] enqueueing "G28 Y"122.335s
[INFO - Marlin:10] endstops hit: X:-0.57 Y:1.68124.137s
[INFO - Marlin:10] busy: processing126.083s
[INFO - Marlin:10] endstops hit: X:-0.57 Y:-180.08126.094s
[INFO - Marlin:10] X:-0.57 Y:-3.00 Z:4.00 E:0.00 Count X:-57 Y:-300 Z:1600126.296s
[INFO - Selftest:10] fwd Y-Axis @50 mm/s126.296s
[INFO - Marlin:10] X:-0.57 Y:-3.00 Z:4.00 E:0.00 Count X:-57 Y:-300 Z:1600130.012s
[INFO - Marlin:10] endstops hit: Y:175.40130.062s
[INFO - Marlin:10] X:-0.57 Y:175.40 Z:4.00 E:0.00 Count X:-57 Y:17540 Z:1600130.062s
[ERROR - Selftest:10] Y-Axis measured length = 178.399994mm out of range <181.000000,193.000000>
Respondido : 16/03/2025 9:40 pm
_KaszpiR_
(@_kaszpir_)
RE: Z Y axis selftest failure
It means your X and Y axis are shorter than expected.
Make sure to redo the assembly.
Respondido : 30/07/2025 7:34 am
super_paces
(@super_paces)
Miembro
I have the same issue. The self test crashed on the Y axis because the max range was only to the 173 or 176, depends on how tight was the belt or the front holder.
I am stuck on this step for two days.
Respondido : 29/10/2025 12:48 pm
