Will 3dsets models fit on a Mini
Tracy
(@tracy)
Not a sales pitch! This is an honest question. Has anyone tried printing a model from 3dsets.com on their Mini? The site says your printer must be 200 x 200 x 180 mm which the Mini isn't. But I looked at all the photos for the Rancher and I suspect the larger parts can be printed diagonally. I emailed the company and got no response - not a good sign.
Napsal : 07/07/2020 10:36 pm
Clemens M.
(@clemens-m)
RE: Will 3dsets models fit on a Mini
It is a lot of work to check if every part fits in the building room of the MINI. I had a quick check of many parts of Body and Chassis and I would say it should work. But some parts will become very tricky to print - for example (Defender): Rear fender for print
For this part the MINI misses 0,5 mm in z direction. Maybe it is possible to find 1 or 2 mm in z direction. Needs some testing.
I would give it a try and if there is realy no way to print it on a MINI it is maybe possible to find someone near you who can help with a bigger building area.
Best regards, Clemens
Napsal : 07/07/2020 11:11 pm
1 lidem se líbí
mark
 mark
(@mark)
If you don't mind making things smaller, you can always shrink things down in Prusa Slicer. Just use the same scale factor for everything and pieces should fit together. I also load things into CAD software and cut them into pieces that can be glued together. Sometimes that is a lot of work, but I'll usually make some modification, add a logo, whatever, while I'm doing it.
Regards,
Mark
Napsal : 08/07/2020 2:50 am
Clemens M.
(@clemens-m)
@marklgoldberg
For these parts it would get very complicated, because the whole car is more than 250 printed parts and what makes it a lot mor difficult is, that there are ball bearings, servos, motors and so on which have to have perfect fit. So in that case using a scale factor I would say is no solution.
Napsal : 08/07/2020 7:59 am
bobc
 bobc
(@bobc)
They have an FAQ : https://www.3dsets.com/faq/
Q: I have a printer with a print area of 150 x 150 x 150 mm. Can I distribute the parts into multiple prints and print the whole model this way?
A: Unfortunately, some parts are too large and require a bed size of 200 x 200 mm so they cannot be printed on smaller beds.
I guess they have a reason for saying that.
Napsal : 08/07/2020 8:39 am
Tracy
(@tracy)
Posted by: @clemens-m
I hadn't considered Z. Good catch. These models are incredible. I'm bummed I can't print one.
Napsal : 08/07/2020 11:38 am
Lvet
 Lvet
(@lvet)
Hello Tracy
I have a friend that is building the Rancher 4x4 with a Prusa Mini. There is only one part that he couldn't print directly and that was the Front Fender (I printed these parts for him).
Looking at the part, I reckon that you could section the part in two, print it separately and bolt it or glue it together. So I wouldn't think it's a show stopper.
Napsal : 02/11/2020 1:42 pm
1 lidem se líbí
