Very flat bed but nothing sticks in 2 corners
Andrew Pawelski
(@andrew-pawelski)
I have a mini for nearly 2 years and it has never really printed well in the bottom right or top right corners.  I recently did the silicon bed mod and now have a beautifully flat bed .07 variance across it.
Yet a first layer calibration still demonstrates it wont stick in the same areas.
Yes clean surface with soap and 100% iso, no skew I can see on the axis
Z is low - i actually gradually went down to past what it should be and getting build up on the caibration square
Only way anythign sticks is using 1mm first layer extrusion width
can anyone suggest anything else to try?
Opublikowany : 07/07/2022 8:50 pm
Please show us a picture of the issue.
Opublikowany : 08/07/2022 7:16 am
Andrew Pawelski
(@andrew-pawelski)
RE: Very flat bed but nothing sticks in 2 corners
Here is my bed
Opublikowany : 08/07/2022 12:40 pm
Andrew Pawelski
(@andrew-pawelski)
And here is part of a bed level test
yes the beds a bit dirty in this photo but same result when properly cleaned
Opublikowany : 08/07/2022 12:50 pm
Er, thank you; that's not what I meant. Please show us the first layer calibration result.
Opublikowany : 08/07/2022 12:54 pm
Chris Laudermilk
(@chris-laudermilk)
Is that the only plate you have? Same problem with other plates?
My other printer gave me fits with a couple of plates until I lightly sanded them with 600 grit sandpaper, then cleaned with soap & water. Now they work great. It's the nuclear option, but it is something to consider if all else fails.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 08/07/2022 1:29 pm
oriddlero
(@oriddlero)
What material and what temperatures are you running? Fans?
If my post helps you please consider downloading & making one of my most popular Prusa-Printables 3D models below:1. Ultimate Printer Knob Upgrade - The Best Knob of Both Worlds 2. Prusa MK3S Right…
Opublikowany : 11/07/2022 11:22 pm
