trapezoidal spindle is wobbling.... normal?
Is it normal for the trapezoidal spindle to wobble a little? Or must the concentricity fit exactly?
Can you observe well when the Z axis moves from top to bottom ...
Also had a problem in the meantime, which was present in the lower third of a loud squeak. A loosening and retightening of the screws of the Z-axis has solved this problem.
Publié : 15/03/2021 6:48 pm
RE: trapezoidal spindle is wobbling.... normal?
It may be slightly bent, I would suggest speaking to prusa chat support on the EShop.
Ce message a été modifié il y a 5 years par Clarmrrsn
Tank you very much!
Publié : 15/03/2021 7:04 pm
