Recommended extruder for the Mini?
TeachThePrints
(@teachtheprints)
Been out of the loop on what's on the market. Got the Mini when it first came out and used it for a while, but never managed to get it working properly, as the nozzle kept clogging.
I want to solve that issue and think a major issue is the weak extruder, because whenever the nozzle is clogged, I can still push the filament through manually. So either better grip or higher torque extruder should do the trick of printing more reliable.
Best Answer by FoxRun3D:
The Bondtech IFS dual drive extruder for the mini is my only recommended upgrade for the Mini. Or the Trianglelabs clone, if you don't need an integrated filament sensor. Both are excellent. I have them on all my minis and haven't had to adjust the idler once in years, using a wide range of filaments.
Prusa Mini FW6.2.4
Publié : 22/01/2024 1:40 pm
RE: Recommended extruder for the Mini?
Publié : 22/01/2024 3:03 pm
1 personnes ont aimé
The Bondtech IFS dual drive extruder for the mini or a selfmade variant:
wbr,
Karl
Publié : 23/01/2024 1:00 am
the idea originates from this model:
Publié : 23/01/2024 1:07 am
Bernies Flexar (CNC milled ALU) model is unfortunately no longer available in its original form (Euro 49.9
wbr,
Karl
Publié : 23/01/2024 1:08 am
TeachThePrints
(@teachtheprints)
It does seem like the replacement extruders come without an extruder motor and instead just connect to the original prusa motor. Is this correct?
Prusa Mini FW6.2.4
Publié : 23/01/2024 5:55 am
_KaszpiR_
(@_kaszpir_)
With Bondtech IFS you reuse original Prusa motor.
With other brands it's worth to double check what is in the package that you buy.
Also worth to check assembly manuals.
Publié : 23/01/2024 7:31 am
Both Bondtech and Trianglelabs reuse the Prusa motor. Never had an issue with it myself. The only clogs I've had after installing the dual drive extruders were utterly self-inflicted, such as trying to load PLA after running high temp filaments such as ASA without cleaning the hotend with cleaning filament or loading at the higher temperature.
Publié : 23/01/2024 12:14 pm
I also mounted the original Prusa stepper on my selfmade flexar extruder. Working since years without any issue.
The idler spring i replaced with 2 strong N52 magnets.
wbr,
Karl
Publié : 23/01/2024 4:49 pm
Tysonsw
(@tysonsw)
Have you tried cleaning the teeth on the Extruder gear? I have printed PLA, PETG and PETG-PC blends with my Stock Mini and it has not missed a step. Neither on 0.25, 0.4 or 0.6.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Publié : 30/01/2024 8:29 am
TeachThePrints
(@teachtheprints)
Yes, I have tried various things over the years.
  • I have cleaned the teeth properly.
  • Adjusted the idler tension by removing the coupling to the hotend to just feed filament through, then starting at zero tension to gradually increase it, until it fully grips the filament.
  • Doing cold-pulls.
  • Using various filaments from PLA to PETG.
  • Printing at 15-20 degrees hotter than normal to lower pressure
  • Doing a complete de-assembly of the extruder.
Posted by: @tysonsw
Prusa Mini FW6.2.4
Publié : 30/01/2024 2:38 pm
Tysonsw
(@tysonsw)
Have you checked that the nozzle is correctly tightened against the heatbrake?
https://help.prusa3d.com/article/changing-replacing-the-nozzle-mini_134235
And also checked the PFTE tub in the heatbrake for damage?
Printables: Tysonsw
Publié : 30/01/2024 2:44 pm
Just get the Bondtech and get on with life 🙂
Publié : 30/01/2024 2:46 pm
TeachThePrints
(@teachtheprints)
Posted by: @fuchsr
The triangle land extruder is on its way.
Posted by: @tysonsw
Yes, I have checked that the nozzle sits tight  and also replaced the PTFE tube in the heartbreak, incase I am incapable of detecting a damaged PTFE tube.
Unfortunately none of it helped. Now it's gonna be a replacement to hopefully solve this issue.
Prusa Mini FW6.2.4
Publié : 30/01/2024 4:04 pm
TeachThePrints
(@teachtheprints)
Got the Trianglelabs extruder now installed for a while and it works flawlessly. Finally, I can just hit print and not have to worry about any clogging issues anymore.
Prusa Mini FW6.2.4
Publié : 11/02/2024 10:56 am
Glad to hear it works well for you!
Publié : 11/02/2024 1:10 pm
