Rate My Mesh
Skreelink
(@skreelink)
Rate My Mesh
I finally got around to installing the bed visualizer in Octoprint and this was the result.
Difference between the highest point and the lowest point is about 160 microns. I guess I at least shouldn't need the silicone mod... This was using the thinner, powder coated sheet.
I think I know, I don’t think I know. I don’t think I think I know, I don’t think I think.
Opublikowany : 19/01/2021 11:00 pm
Crawlerin
(@crawlerin)
RE: Rate My Mesh
Dang ... 10/10, would bed level again.
Opublikowany : 21/01/2021 1:28 am
Area51
(@area51)
RE: Rate My Mesh
This is just spot on... 😀
Opublikowany : 21/01/2021 1:40 am
Skreelink
(@skreelink)
RE: Rate My Mesh
Did a bit of tweaking to the X end and managed to get it all within 100 microns between the lowest and highest points. I kinda want to see what a 7x7 mesh would look like now.
Opublikowany : 25/01/2021 8:22 pm
Crawlerin
(@crawlerin)
RE: Rate My Mesh
Is this with stock Y carriage or did you do silicone mod?
Opublikowany : 27/01/2021 6:40 pm
Skreelink
(@skreelink)
RE: Rate My Mesh
Posted by: @crawlerin
Stock assembly.
Opublikowany : 27/01/2021 6:41 pm
ALEX
 ALEX
(@alex-17)
RE: Rate My Mesh
@skreelink
How did you tweak the X axys? And what gcode are you using for bed visualizer? Trying to work out if there is a way to load the mesh at each print start, rather than manually update it
Opublikowany : 30/01/2021 3:12 pm
Skreelink
(@skreelink)
RE: Rate My Mesh
@alex-21
You can tweak the X axis with the screws at the end as outlined in Prusa's knowledge database: https://help.prusa3d.com/en/article/xz-axis-skew-correction-mini_158518
The GCode for the Mini for the bed visualizer is as follows:
M104 S170 ; set extruder temp for bed leveling
M140 S60 ; set bed temp
M109 R170 ; wait for bed leveling temp
M190 S60 ; wait for bed temp
G28 ; home all without mesh bed level
@BEDLEVELVISUALIZER ; instruct plugin to start recording responses from printer.
G29 ; mesh bed leveling
You can remove the mesh bed leveling code from the gcode of your print files, but the mini does not save the data to memory, so it's a moot point and has to run before every print.
Opublikowany : 30/01/2021 5:03 pm
