PrusaSliver v2.1 and color
marktaylormt303
(@marktaylormt303)
Typo "Prusa Slicer"
I am trying to work out how to export from CAD to print in color. The only way i can find would be to export everything as STL then explode it in PrusaSlicer and try to assign color to each object. However there are 20-50 objects to do with this and its real time consuming (and not tested).
We can however export each batch of parts we need as color, but then cant line them up in PrusaSlicer again... so whats the best way?
Postato : 25/11/2019 12:23 pm
RE: PrusaSliver v2.1 and color
Don't know about different colours as its not something I have tried but you can load other stl files into a model already on the plater.  Just select it and right click with load part.  The new imported part is then logically grouped under the original model and can be moved around as you like, even moving if off the build plate which cant be done with separate models (as all models must touch the build plate to be printable).
Postato : 25/11/2019 12:51 pm
Greybeard3D
(@greybeard3d)
Drag all the files back into slicer at same time it’ll ask if you want to import a multi color part.  Say yes.
Postato : 26/11/2019 5:44 am
