[Resuelto] Prusament PETG Clear does not load
Klaus Krämer
(@klaus-kramer)
I am just getting crazy: The just opened Prusament PETG Clear wont load. It gets driven by the extruder for e.g. 1.5 cm and then it gets stuck.
I have 3 times changed to another Prusament PETG (Ultramarine) and it loads perfectly.
Measurement of the clear filament shows a diameter between 1.739 and 1.743 mm, the Ultramarine one goes down to 1.731 an 1.738. All within specifications.
Has anyone had similar experiences? Should I loosen the pressure of the extruder spring? Thapart that went into the tranport wheel has been somewhat flattened and has now a width up to 2.0 mm.
The Clear PETG is the first filament that does not pass the extruder at all - no such experience with any other PETG or PLA.
Best Answer by FoxRun3D:
Sure, loosening the idler screw is the first thing I'd try. And then double check that the spool says PETG not ASA 🙂
Respondido : 03/02/2023 8:05 pm
RE: Prusament PETG Clear does not load
Respondido : 03/02/2023 8:13 pm
1 les gusta
Klaus Krämer
(@klaus-kramer)
First thing I'll do this Sunday ...
Respondido : 03/02/2023 8:16 pm
Klaus Krämer
(@klaus-kramer)
Simple and maybe silly question: I suppose turning the idler screw counterclockwise will loosen the pressure on the filament?
Respondido : 03/02/2023 8:51 pm
JustMe3D
(@justme3d)
Counterclockwise loosens the load on the spring, thus reducing pressure on the gears.
Clear filament - does the problem go away if you disable the filament sensor?
Respondido : 03/02/2023 9:01 pm
1 les gusta
Links herum
Respondido : 03/02/2023 10:06 pm
1 les gusta
Klaus Krämer
(@klaus-kramer)
Shoving the filament into the extruder leads to a suden and palpable stop, when something clogs at the exit of the extruder.
I suppose, clear PETG is a little bit more squaschy than others - only some gut feeling.
Tomorrow I'll know more after loosening the spring.
Respondido : 04/02/2023 7:49 pm
Mark the filament when it hits the stop then unload it and offer it up in the same position to see how far down the block is...
Respondido : 05/02/2023 12:16 am
1 les gusta
Klaus Krämer
(@klaus-kramer)
A quarter turn counterclockwise / left of the idler screw did the trick. Taking tension from the filamen had been the right decision. Now I hope PLA filament will work with lowered tension too. I'll see ...
Thanx for supporting me - it helped me to confidently try that!
Respondido : 05/02/2023 10:46 am
That's the reason I installed Bondtech extruders on my Minis. The stock extruder works but is very finicky and sensitive to different filament types. I haven't had to adjust the tension on the Bondtechs once, and haven't had any clogs or heat creep issues. (To be precise, one of the Minis has the Bondtech IFS, the other a Trianglelab clone of the original Bondtech extruder. No difference).
Respondido : 05/02/2023 11:58 am
Klaus Krämer
(@klaus-kramer)
@fuchsr: Wenn's wieder fuxt, wird getauscht ... 👍
Respondido : 05/02/2023 12:37 pm
