Prusa Mini Settings 0.6mm Nozze, Flex Filament (98A) - Best settings so far
Philipp
(@philipp)
Everyone, having searched times over times for the best settings to print flex filament on the mini - with okay'ish results, but not truly satisfying, I just finished my very best of all times print and would like to share both results and settings. Hope that I can make someone else's life, who is in the same situation like me, easier:
Filament: Extrudr Flex Medium 98A
Nozzle: 0.6mm (this was a game changer for TPU)
https://ibb.co/TWJJJbn
https://ibb.co/d4zt11w
https://ibb.co/SJmdLd7
https://ibb.co/5rkmfWn
https://ibb.co/hy24njS
This topic was modified před 4 years by Philipp
Napsal : 14/01/2022 3:08 pm
2 lidem se líbí
ANTHONY
(@anthony-2)
RE: Prusa Mini Settings 0.6mm Nozze, Flex Filament (98A) - Best settings so far
Totally agree 0.6 nozzle is thé best ,have you got thé profil.i will share mine too
Napsal : 16/01/2022 12:13 pm
ANTHONY
(@anthony-2)
First attempt good i used a simple figure to test support and you Can see it is good , i have some cooling issue in other side and need to reduce Speedy on it and check again
Napsal : 16/01/2022 1:21 pm
Philipp
(@philipp)
Profiles see attached - the pages show the changes I made from the default values! your print looking good, too!
Napsal : 16/01/2022 4:43 pm
ANTHONY
(@anthony-2)
Thank you i will share mine too i am on the cell phone
Napsal : 16/01/2022 6:24 pm
1 lidem se líbí
newyen
(@newyen)
Hey Anthony,
I know this is quite some time ago but do you still have those print settings?
In general maybe also for other people using this material on the Mini, I needed to quite reduce the print temperature as I was getting terrible results otherwise. The material was all oozing, bubbling and making weird sounds. I first thought it might have been humidity in the filament but reducing the temperature really worked it for me.
Here are my settings:
Napsal : 14/10/2023 4:13 pm
